No voice between IPcommunicators via VPN client
Apr 29th, 2010
I have problem when I try I set a call between IP communicator via VPN client in both sides, in both sides there is no voice.
James Hawkins Fri, 04/30/2010 - 00:50
The RTP stream will flow directly between the PCs running IPC. Have you established that you have IP connectivity between them? i.e. can each PC ping the other?
