RV082 used dual wan download speed slow
Apr 29th, 2010
  I have a RV082 and I used dual wan , every ISP downstream is 10MB/s. two ISP downstream total 20Mb/s.Rv082 use loadblance mode,but total Lan PC download speed was 30kb/s-90kb/s,is very slowly .I find similar question inthe forum ,but i can not .please help me
  thanks
cchamorr Mon, 05/10/2010 - 18:05
  • Silver, 250 points or more
Ok, several things here:
- Make sure that when you connect every individual LAN you get the full downstream speed.
- Make sure that it is not a PC problem, check with different PC's to see if the speed is the same on all of them.
- Download latest version of Firmware, you can get it from the cisco website, here is the link: http://tools.cisco.com/support/downloads/go/PlatformList.x?sftType=Small+Business+Router+Firmware&mdfid=282414011&treeName=&mdfLevel=null&url=null&modelName=Cisco+RV082+8-port+10%2F100+VPN+Router+-+Dual+WAN&isPlatform=N&treeMdfId=&modifmdfid=null&imname=&hybrid=Y&imst=N
- If you have to apply the new firmware make sure that you reste the device to factory defaults aftre the upgrade.
- Disable SPI under the firewall settings.
Hope this helps.
415386767 Mon, 05/10/2010 - 20:44
HI:
I am extremely grateful for your help
The problem Problem has been solved.
The problem is on the fiber-optic transceivers. I re-changed a fiber optic transceiver what connected ISP .
But the model is configured to load blance ineffective.
So I want to know the RV082 working principle of load blance,Please help explain.
Yours sincerely
Vincent Zhang
2010-05-11
张勇勇
发件人: cchamorr
发送时间: 2010-05-11 09:06:20
收件人: [email protected]
抄送:
主题: New message: "RV082 used dual wan downloadspeed slow"
415386767,
A new message was posted in the thread "RV082 used dual wan download speed slow":
https://www.myciscocommunity.com/message/47048#47048
Author : cchamorr
Profile : https://www.myciscocommunity.com/people/cchamorr
Message:
Related Content
