Possible Crypto Overlap and NAT ACL open to Subnet vs. Host
Answered Question
Apr 29th, 2010
For a PIX 515E 6.3(5)
I have the following ACLS:
Crypto ACL List
access-list ipsectraffic permit ip host 192.168.7.221 object-group pdvcorp-backup3-to-db1-datacenter
access-list ipsectraffic permit ip host 192.168.7.222 object-group pdvcorp-backup3-to-db1-datacenter
access-list ipsectraffic permit ip object-group corphosts-datacenter 192.168.10.0 255.255.255.0
access-list ipsectraffic permit ip object-group productionhosts-datacenter object-group access-productionhosts-datacenter
In the above Crypto ACL list, hosts 192.168.7.221 and 192.168.7.222 are both also part of the object group 'productionhosts-datacenter' referenced in the same ACL list. What are the implications of having the same hosts referenced in the Crypto ACL, if any?
No NAT Access List
access-list nonat permit ip 192.168.7.0 255.255.255.0 192.168.10.0 255.255.255.0
In relation to the Crypto ACLs above, is there an issue (security wise or other) with opening the complete Subnet with a NoNAT ACL to save on the having to nail down each host.
Dan
Correct Answer by droeun141 about 6 years 12 months ago
It doesn't matter, you can use the same source with multiple destinations.  No issues either with the nonat.
Overall Rating: 5 (1 ratings)
Correct Answer
droeun141 Thu, 04/29/2010 - 20:48
trippi Fri, 04/30/2010 - 10:58
As droeun141 said, you should be fine
Related Content
