ASR 9000 - V3.9.0 MIBs
msinno123
Is the version of MIBs at: ftp://ftp-sj.cisco.com/pub/mibs/supportlists/asr9000/asr9000-supportlist.html the latest versions? I have downloaded MIBs form Cisco's FTP site and the versions appear to be more recent than what is listed in this FTP site.  Does this mean the ASR9k supports the older version of the MIBs or is the FTP site just not updated?
6 Replies 6
xthuijs
The mib list you have there is what is specifically tested against the ASR9000.
It does not list some mibs that are supported though. The reason for that is the following.
Our SW development is separated in two parts, Platform dependant (PD) and platform independant software (PI).
The PD is what is specific to say the ASR9000. PI components such as OSPF or BGP have no relation to the hardware it is running on.
Therefore you may not see for instance the ISIS mib listed on the 9k list, but it is an XR supported MIB. Since the A9K doesn't do anything specific to this protocol, the ISIS mib is completely supported.
So rule is, mib list you have is supported either case and tested specifically. If not in the list but in the XR supported mib list AND the functionality has no hardware dependency THEN you can assume support also.
If it falls outside of these two, we can't claim support for it.
xander
sr Tech Lead ASR9000
CCIE
Hi Alexander,
                         Along with this discussion may I know how to enable ftp services in asr9k. In ios11.3  we can use "ftp-server enable" command for enabling the services. But this is not working in XR.  In XR is there any command required for enabling the ftp-server ?? Pls give me a response.
Currently there is no ftp server support in XR.
xander
How bout sftp? Almost sure it worked on 4.1, but certainly not working on 4.2.
Both client and server are supported for SFTP.
SFTP server was introduced in XR 3.3
You need the crypto pie for that.
There was a bug in 42,  CSCtx47909 that broke the sftp server. Fixed in 421 onwards.
thanks
xander
Yup, 4.2.0 for me. Didn't know about the bug. Thanks a lot.
