CNR 7.x in backup mode - licensing ?
Apr 29th, 2010
Hello
For two physical servers to run CNR 7.x in backup mode,
do I need 2 licenses or just one?
I have single license, can install it on server #1.
Server #2 requests license after installation and if
server #1 is online, server #2 doesn't install the license (same license as on #1).
It just keep showing buttone "Browse" and "Cancel".
If I shut down server #1, then after 5 min server #2 installs the license as it should be.
Looks for me that they talk between and inform each other about
license, so I need two licenses apparently. Looking for
confirmation.
Appreciate any feedback
Thank you
Alex
a.gesse Fri, 04/30/2010 - 03:46
Ok, thanks Nael Mohammad
I have license for 5K nodes/ip on server #1. To use second server #2 as a backup server
do I need to purchase another 5K nodes/ip license or I can utilize existing one?
Thank you
Alex
Nael Mohammad Fri, 04/30/2010 - 09:16
  • Silver, 250 points or more
You can use the same licenses as enforcment is based on nodes not the amount of servers.
