CME 4.1 - Long Distance Calls
Apr 29th, 2010
Running CME 4.1 on 2811, having issue making long distance calls. Reloading the router corrects the issue for a couple of days and then the issue arise again. Displaying voice dial-peer shows no failed calls. When attempting to make call, getting 1 or 0 is not required and if you try dialing not using 1 get 1 or 0 is required. Wondering if it is an hardware issue or a bug in this version.
paolo bevilacqua Fri, 04/30/2010 - 04:01
  • Hall of Fame,
    Founding Member
No enough info give. No config, no exact IOS version, and what's the 0 1 digits.
