04-29-2010 10:48 PM
I need to upgrade from LMS 3.1 to 3.2
Part of the upgrade process is that it does an automatic backup. Is it possible to disable this backup step and just use our "normal" backup if needed? Or is the backup in the upgrade process different in some way? Disk space is at a premium on this server. Thanks, Graeme
Solved! Go to Solution.
04-29-2010 10:59 PM
The automatic backup is no different than a normal backup. If you're absolutely sure you have a good backup, you can run the setup script or
executable with the "nobackup" option:
Windows:
setup.exe nobackup
Solaris:
setup.sh -b nobackup
04-29-2010 10:59 PM
Windows:
setup.exe nobackup
Solaris:
