Cisco 3745
gil.juguilon
I need to upgrade the network module of a Cisco 3745 from DS3 (DS3 port) to OC3.
I have read the document below and it seems that NM-1A-OC3-POM (MM) will be the suitable module for it.
http://www.cisco.com/en/US/prod/collateral/routers/ps259/prod_end-of-life_notice0900aecd806f43e4.pdf
I just wanted to be sure if the module(NM-1A-OC3-POM) will be compatible with Cisco 3745?
Or will this module is suitable for 3800's only?
Advace thanks for the help.
Gil
Ganesh Hariharan
Gil
Hi Gil,
Check out the below link the module supoprted in cisco router 3745 and as far as NM-1A-OC3-POM it seems to be supported with cisco 3800 routers.
http://www.cisco.com/en/US/docs/routers/access/interfaces/nm/hardware/installation/guide/ConntATM.html
http://www.cisco.com/en/US/prod/collateral/routers/ps5855/prod_qas0900aecd80300030.html
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
