LMS 2.6, how to re-initialize DFM 2.0 database?
andrea.meconi
Level 2
Level 2
DFM 2.0.12 is working with some errors.
I want to re-initialize the database and I'm looking for a step-by-step guide.
Regards.
Andrea
Joel Monge
1. Login to the server as local Administrator. Then go to a DOS prompt and enter:
net stop crmdmgtd
2. Go to C:\program files\CSCOpx\bin and issue:
perl dbRestoreOrig.pl dsn=dfmInv dmprefix=INV npwd=cisco
perl dbRestoreOrig.pl dsn=dfmFh dmprefix=FH npwd=cisco
perl dbRestoreOrig.pl dsn=dfmEpm dmprefix=EPM npwd=cisco
*Note: The above assumes you use "cisco" as the database password. Change it to whatever you like.
3. Go to NMSROOT\CSCOpx\objects\smarts\local\repos\icf\.
4. Delete the files DFM.rps, DFM1.rps (DFM1 only in LMS 3.0 or above):
del DFM.rps
del DFM1.rps
5. Type:
net start crmdmgtd
  Check the below DOC which contains similar steps and details about database troubleshooting:
https://supportforums.cisco.com/docs/DOC-8796
Joel Monge
net stop crmdmgtd
del DFM.rps
del DFM1.rps
5. Type:
net start crmdmgtd
Small clarification I omitted, NMSROOT stands for your LMS installation path which by default is C:\Program Files\
CSCOpx. If it is different just change the patch accordingly.
Many thanks for your help Joel!
Regards.
Andrea
