AgentSkillTargetID not referenced in Agent table
Answered Question
Apr 30th, 2010
I have a problem with an agent configuration. I cannot update this agent configuration through the Agent explorer tool.
The consistency Check on Targets in ICM says the following:
Error found while checking: Targets
Agent:SkillTargetID not referenced in Skill_Target table.
It seems that the table Skill_Targets doesn't contain the this Agent's SkillGroupSkillTargetID.
How can I possibly fix this issue?
Many thanks
Overall Rating: 5 (1 ratings)
david.macias Fri, 04/30/2010 - 05:50
Have you or someone withint your team been manually making updates to the ICM tables?  Without actually seeing the tables and the error I can't really give you a solution, can you just delete the agent and create a new one?
edimarzio Fri, 04/30/2010 - 06:26
No I cannot delete the Agent because of this reason: I don't know how happened, but the same Skill TargetID is now associated to a skill group instead to the Agent. Agent and Skill Group have the same Skill Target ID.
For instance: if now I add a route to the Skill Group Explorer tool, I find the same associated to the agent. I would only like to delete this broken configuration: that's all.
The database looks like the following (SkillTargetID 5017 is shared among an agent and a skill group)
select SkillTargetID,PersonID,PeripheralID  from t_Agent
where PeripheralNumber = 10000
SkillTargetID    PersonID    PeripheralID
5017    5000    5000
select * from Skill_Target
where SkillTargetID=5017
SkillTargetID    SkillTargetType
5017    2
SkillGroupType=2 means that this skill Target ID is related to an Skill Group, and not to an Agent.
select * from Skill_Group
SkillTargetID    EnterpriseName
5017    CS_CCM.CS_Test_SG
It seems that some update failed on the DB, and this got corrupted. But only for this single agent configuration.
I don't know how this is happened. Nobody has ever played  with the DB. It's the first time this happened to me, I work with ICM  since a lot of years. I trust the customer too, who is quite expert and  knows the system very  in detail, since he is using ICM since 4 without  issues.
edimarzio Fri, 04/30/2010 - 07:16
I found that this configuration is wrong only on one AW awdb.
Bot the central controller, as well as the other AWs have the correct configuration. That is the following:
5012    5000    5000
(1 row(s) affected)
5012    3
5017    2
(3 row(s) affected)
Do you think that an AW restard could fix the issue?
edimarzio Fri, 04/30/2010 - 07:53
Geoff, thank you very much for your suggestion!
Very appreciated!
