DFM 3.0.1 device discovery problem
Apr 30th, 2010
Hi, I have 329 devices in DFM that are "pending", I'm having trouble porgressing any more than that. Please advise.
Joel Monge Fri, 04/30/2010 - 07:03
First thing you should do is upgrade to DFM 3.0.5. There are known memory leak problems in earlier versions.
mdruppe98 Fri, 04/30/2010 - 07:11
It looks like 3.0.1 is the highest version I can get. I'm running LMS 3.0 and I upgraded to DFM 3.0.1 a few days ago. When I select download updates for DFM it says "no updates available for selected products".
mdruppe98 Fri, 04/30/2010 - 07:30
Ok, great. thanks. Let me try that and then try updating to DFM 3.0.5.
mdruppe98 Fri, 04/30/2010 - 11:53
I upgraded everything and now I'm at DFM 3.0.5. I imported all the devices but I'm still showing them as learning int the device summary.
Joel Monge Fri, 04/30/2010 - 12:01
How long have you waited for the discovery? Go to DFM > Device Management > Rediscover/Delete and check at what percentage the devices are stuck in learning. Are all the devices stuck or are some getting discovered?
mdruppe98 Fri, 04/30/2010 - 12:18
I spoke too soon!!!! They are "known" now. Thanks a million for your help!
