Can not del not enabled item from ASDM Access Rules
Apr 30th, 2010
We are running ASDM ver 5.0(3)F FWSM ver 3.1(13), Java ver 1.4.2_03.
I run a problem:
After I made config modification (for Access Rules), such as, just changed port num from X to Y, after apply, the new access list item is there, but old one is there (but not enabled) too. When I del or cut the old ones, then apply, it always give me the error, like the following:
[ERROR] no access-list IT-Support-VLAN100_access_in extended permit tcp host x.x.x.x y.y.y.y 255.255.255.0 eq 1248 inactive
Specified access-list does not exist
That means the access-list is not in FWSM, but it still shows up in GUI.
Is any way we can really remove them (del ones) from GUI? Or any workaround to remove them?
Thanks.
gy
Jennifer Halim Fri, 04/30/2010 - 06:56
  • Cisco Employee,
I would suggest that you upgrade the ASDM to the latest version: 6.2.1F
