Cisco 2821 - Crashinfo file
Apr 30th, 2010
I am trying to find where Cisco 2821 saves crashinfo file and how do i retrieve it.
This is urgent, can anybody please help me with the information.
Thanks in advance.
Manmohan.
Reza Sharifi Fri, 04/30/2010 - 07:37
  • Cisco Designated VIP,
    2017 LAN
Hi Manmohan,
It should be saved on the flash
Reza
manmohankrishna Fri, 04/30/2010 - 07:42
Hello Reza,
Unfortunately i am not finding it. By any chance do you have any reference link.
Thanks in advance.
Manmohan.
Reza Sharifi Fri, 04/30/2010 - 07:48
    2017 LAN
Manmohan,
What does sh flash or sh flash all shows?
Reza
manmohankrishna Fri, 04/30/2010 - 07:52
here is show flash all output
------------------ show flash: all ------------------
-#- --length-- -----date/time------ path
1     38220736 Mar 9 2008 09:25:08 +00:00 c2800nm-advipservicesk9-mz.124-12c.bin
25640960 bytes available (38223872 bytes used)
******** ATA Flash Card Geometry/Format Info ********
ATA CARD GEOMETRY
   Number of Heads:       4
   Number of Cylinders    978
   Sectors per Cylinder   32
   Sector Size            512
   Total Sectors          125184
ATA CARD FORMAT
   Number of FAT Sectors  62
   Sectors Per Cluster    8
   Number of Clusters     15592
   Number of Data Sectors 125024
   Base Root Sector       252
   Base FAT Sector        128
   Base Data Sector       284
  ATA MONLIB INFO
   Image Monlib size = 61240
   Disk monlib size = 65536
   Name = piptom-atafslib-m
   Monlib Start sector = 2
   Monlib End sector = 121
   Monlib updated by = C2800NM-ADVIPSERVICESK9-M12.4(12a)
   Monlib version = 1
------------------ dir nvram: ------------------
Directory of nvram:/
  226  -rw-       12687                      startup-config
  227  ----          46                      private-config
  228  -rw-       12687                      underlying-config
    1  -rw-           0                      ifIndex-table
    2  ----          13                      persistent-data
245752 bytes total (230919 bytes free)
rahurao Fri, 04/30/2010 - 08:04
Hi Manmohan,
As per Reza we cannot see any kind of crash info file getting saved on the flash.
Can you check the logs and try to see if the crash info file was saved on flash.
You might see the output like "writing crashinfo on the flash"
Rahul
Reza Sharifi Fri, 04/30/2010 - 08:10
    2017 LAN
Can you check " sh ver" and see if you see a "Bus Error exception"?
Reza
smitesh kharecha Fri, 04/30/2010 - 23:16
  • Silver, 250 points or more
If show version says system restarted due to bus error or software, etc..
It should be present in flash as crashinfo.
However if you are not able to find that, then simply run command
sh tech
Smitesh
