SSL VPN (AnyConnect) and Customize Preconnect Message
Answered Question
Apr 30th, 2010
I was able to configure the Start Before Logon message and Preconnect messages but was wondering where the file is located to modify the default message.  It currently displayes the default message "This is a pre-connect reminder message."
Where is the file located to customize or change this?  I read that control is localizable and can be found in the AnyConnect message catalog but cant seem to find this.  Is their something I am missing?
Correct Answer by Paul Carco about 7 years 4 weeks ago
You can export the template to your local drive and then edit the field shown in the second screen shot or when you export the template fils in the first screenshot you can edit locally and then import it with the change already made..
Do not change the msgid  you want to edit the msgstr directly below the msgstr
Overall Rating: 5 (1 ratings)
Correct Answer
Paul Carco Fri, 04/30/2010 - 18:21
niall-wilkins Tue, 05/04/2010 - 07:10
I do however seem to be missing something.  When I go to anyconnect customization I do not see an option for GUI texts and messages.  I only have resoruces, binary and installs.  If their somthing I need to install to have this show up?  I am using ASDM 6.0 (3) and ASA 8.0 (3).
Paul Carco Tue, 05/04/2010 - 07:49
What version of code are you running..?
I am running
Cisco Adaptive Security Appliance Software Version 8.2(1)
Device Manager Version 6.2(5)
AnyConnect 2.4.1012
niall-wilkins Tue, 05/04/2010 - 11:34
Upgraded ADSM to 6.2(5) and ecerything is there to make the changes
