WAP4410N Vlan
Apr 30th, 2010
We have 2 Vlans
Voice Vlan50
Data Valn75
When Setting up the WAP4410N we are using WEP 128 why can I not use Key 1 for both Vlans and have it different passwords
Example
Voice
Key 1 = 11111111111111111111111111
Data
Key 1 = 88888888888888888888888888
It does not matter if I change Key1 to all 1's for Voice it changes Key1 to all 1's for Data...If I change Key1 to all 8 for Data it changes Key1 to all 8's for Voice...
Any help is appreciated, this is the only Model of AP that is doing this...
--Scott
Kayle Miller Fri, 04/30/2010 - 09:00
Scott,
     I could be wrong but I believe on that access point the WEP Key slots are shared. Meaning that the Key database is the same for all SSID's so you need to set the Key 1 to 1111111111111111111 and Key 2 to 88888888888888888888   then set SSID #1 to Key 1, and SSID #2 to Key 2.
Hope this helps.
albolabris Fri, 04/30/2010 - 09:33
Hey Kayle,
Yes that is what it looks like is there any way to stop that...I need to keep all the different AP we have consistent…
Thanks, Scott
Related Content
Trending Topics - Security & Network
