Router 2801 don´t connect
Apr 30th, 2010
I have a router 2801, but i can't connect with the console cable, i prove many configurations and bits rate, but i can´t see data in the hyperterminal
thanks for your help
mathausxp Fri, 04/30/2010 - 17:27
I have a router CISCO 2801, but i cant get connected with the console cable; i've tried many configs and bit rate, but i cant see any data in the hyperterminal
sorry for the redaction, but my english is very bad.
Federico Coto F... Fri, 04/30/2010 - 17:32
Things you can check:
1. Try different cable
2. Try from a different computer
3. Try using a different program such as Putty, Teraterm, SecureCRT, etc.
4. Check the lights on the 2801 to make sure it's booting fine.
Let's isolate the issue.
Federico.
Reza Sharifi Fri, 04/30/2010 - 18:12
Hello Pedro,
In addition to what Federico said. Is the console cable connected to your PC or laptop by regular 9 pin adaptor that comes with Cisco devices or by USB?
Reza
mathausxp Wed, 05/05/2010 - 07:49
yes, i try with a pc using COM1, and with a laptop using a USB-serial adaptor.
