David Hailey Fri, 04/30/2010 - 19:36
  • Purple, 4500 points or more
You shouldnt need to do either.  You can upgrade directly to 7.1 from 6.1.  I believe you need to be on 6.1(3b)SU1 at a minimum - so read the release notes for 7.1 and find out what versions are supported for direct upgrade.
Hailey
Please rate helpful posts!
Rob Huffman Fri, 04/30/2010 - 20:53
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Yancy,
I'm just going to add some further notes to the good tips from Hailey (+5 my friend!)
You will need to take a step back and do your "due diligence" before moving ahead with this upgrade. You need to check the CUCM upgrade compatibility, the server support for this version, you will need a Software Feature License for 6.x to 7.x, you'll want to make sure your IP Phones are at a release that will move forward to 8.5(3) (7941/61, 7942/62, 7945/65). there are probably some other considerations as well that I'm missing right now (think Friday night Don't just jump in with both feet!
Release Notes for Cisco Unified Communications Manager Release 7.1(3b)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/7_1_3/cucm-rel_notes-713b.html#wp593770
Supported Cisco Unified Communications Manager Upgrades for Release 7.1(3x) through 7.1(5x)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp176862
Supported Cisco Unified Communications Manager Releases by Server
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
These documents/Links below are sometimes over-looked but contain significant UC upgrade Paths/strategies/recommendations. There is alot of info to weed through but will certainly save you from "taking it on the chin".
System Installation and Upgrade Manual for IP Telephony Enterprise and Midmarket
http://www.cisco.com/en/US/docs/voice_ip_comm/uc_system/UC7.0.1/ipt_system_inst_upg/suimt701.pdf
Cisco Unified Communications System Documentation
http://www.cisco.com/en/US/docs/voice_ip_comm/uc_system/unified/communications/system/ucstart.htm#Cisco_Unified_Communications_System
Cisco Unified Communications Compatibility Tool
http://tools.cisco.com/ITDIT/vtgsca/VTGServlet
Hope this helps! And best of luck!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
Jaime Valencia Sat, 05/01/2010 - 06:53
  • Cisco Employee,
  • Hall of Fame,
    2011
Just to add a clarification note I believe it's missing:
a) backups/restores are in the EXACT SAME VERSION. This includes any SR or ES you might have. So restoring a 6.X into a 7.X install is just not possible.
b) DMA is exclusively for Windows to Linux migrations. There is no migration tool as such between CUCM versions running over Linux. At most you could use BAT with the restrictions and changes you might need to perform between versions.
The whole upgrade process has already been covered by Rob and Hailey but just for you to get your ideas straight.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Rob Huffman Sat, 05/01/2010 - 08:43
  • Hall of Fame,
    Founding Member
Hey Java,
Thanks for jumping in here Your additions should help clarify the
whole process for Yancy. +5 points for you buddy!
Cheers!
Huff
