techguy73 Sat, 05/01/2010 - 00:43
  • Bronze, 100 points or more
If you mean how to reduce the time of recovery to come out of an SRST mode, you can utilize the parameter in Device-pool putting in the number of seconds.
hth
Harmit Singh Sat, 05/01/2010 - 00:52
  • Cisco Employee,
Hi Nirmal,
Like Techguy mentioned, If you are looking for increasing / decreasing the time before which the IP Phone falls back to the CUCM from SRST mode, then you need to go under the Device Pool of that IP Phone and set the value (in seconds) for "Connection Monitor Duration":
This setting defines the time that the Cisco Unified IP Phone monitors  its connection to Cisco Unified Communications Manager before it  unregisters from SRST and reregisters to Cisco Unified Communications  Manager. To use the configuration for the enterprise parameter, you can enter -1  or leave the field blank. The default value for the enterprise parameter  equals 120 seconds.
Harmit.
