cme help please
Answered Question
May 1st, 2010
Hi Expert..
I just wondering, if I have the topology below.... So, if RouterC would like to call RouterA.. how RouterB forward RouterC call to RouterA?
Is there any features or options should I use?
And in this topology, eigrp is involve (I can ping the host on RouterA from RouterC but I cannot ring the ip phone on RouterA)
RouterA---------------RouterB---------------RouterC
Ip phone 2000       IP ph 2001                IP ph 2002
Thanks in advance
Correct Answer by david-lima about 6 years 8 months ago
Hi Terrence, first in your router C you should have two  voip dial-peers; one pointing to the router A and the other one pointing to the router B.
Router C
dial-peer voice 10 voip
descrription ToRouterA
destination-pattern 1...
sesion target ipv4:IP CME Router A
dial-peer voice 20 voip
descrription ToRouterB
destination-pattern 2...
sesion target ipv4:IP CME Router B
Share your config if is possible .
hth
Change the destination-pattern as your needs.
David
Overall Rating: 5 (1 ratings)
Correct Answer
david-lima Sat, 05/01/2010 - 18:16
Router C
hth
David
