Cisco 6500 support LACP & PaGP on the same module?
Answered Question
Hi Sir ...
We had experienced same problem on configing etherchannel. Now we are preparing the configuration about etherchannel on 6500 chassis. But, some paper tell us that Cisco4000 series donot support LACP & PaGP on the module. Is it real?
By the way, Cisco 6509 or IOS could allow engineer config etherchannel LACP & PaGP on this same Giga ethernet module? or TenG Module?
Thanks You!
sean
Correct Answer by Giuseppe Larosa about 6 years 9 months ago
Hello Sean,
as Ganesh's links should show some old CatOS based LAN switches allowed to configure the bundling protocol per module/linecard only.
set channelprotocol lacp 3
!--- All ports in module 3 are in LACP channel mode.
This limitation is not present on IOS based C6500 or C4500, so you should be able to have PAGP on bundle1 and LACP on bundle2 with member links that are on ports of the same linecard
Hope to help
Giuseppe
Correct Answer by Ganesh Hariharan about 6 years 9 months ago
Hi Sir ...
Thanks You!
sean
Hi Sean,
Check out the below link for configuring etherchannel using LACP or PAGP in cisco 6500 and 4000 switches
https://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.1E/native/configuration/guide/channel.html
https://www.cisco.com/en/US/tech/tk389/tk213/technologies_configuration_example09186a0080094470.shtml
Hope to Help !!
Remember to rate the helpful post
Ganesh.H
Correct Answer by Reza Sharifi about 6 years 9 months ago
Hi sean,
Both 6500 and 4500 support Etherchannel using LACP and PAGP. You can also use 10Gig ports or 1Gig ports.
Reza
Overall Rating: 5 (3 ratings)
Correct Answer
Reza Sharifi Sat, 05/01/2010 - 20:48
Hi sean,
Reza
Correct Answer
Ganesh Hariharan Sun, 05/02/2010 - 07:54
Hi Sir ...
Thanks You!
sean
Hi Sean,
Hope to Help !!
Ganesh.H
Correct Answer
Giuseppe Larosa Sun, 05/02/2010 - 11:42
Hello Sean,
Hope to help
Giuseppe
