Cisco 802.11a
Answered Question
May 2nd, 2010
Hey Expert:
As we all know    while using 802.11 b/g we separate channel 1 ,6,11. how we separate channel 802.11a
waiting for prompt response
Correct Answer by Surendra BG about 6 years 10 months ago
I hope the last 4 are not used in any APs other than 15XX mesh cisco APs ..
Hi Faizan,
If u open up the WLC RRM page you can see 23 channels that are non-overlaping.. we can use these channels back to back.. the below link will provide even more information..
http://en.wikipedia.org/wiki/List_of_WLAN_channels
http://www.vocal.com/redirect/802_11a.html
Surendra
Correct Answer by Surendra BG about 6 years 11 months ago
There are 23 non overlapping channels in 802.11A.. they are..
36, 40, 44, 48, 52, 56, 60, 64 , 100 , 104 , 108 ,116, 120, 112, 124, 128 , 132, 136 , 140,  149 , 153 , 157 , 161.
I hope the above answered your question..
Surendra
Overall Rating: 5 (3 ratings)
Correct Answer
Surendra BG Sun, 05/02/2010 - 07:26
  • Cisco Employee,
Surendra
Faizan Khursheed Mon, 05/03/2010 - 12:57
thnaks surendra
its mean i can use 36 40 44 48 side by side they wont interfer  like 1, 6 ,11   but i read in cisco documnet  must user  upper four band and lower 4 band  while using 802.11a   correct me if im wrong
Thanks again
Correct Answer
Surendra BG Mon, 05/03/2010 - 20:22
  • Cisco Employee,
