DLSW and SNASW problem
May 2nd, 2010
I have the following config:
IBM PCOM on E0 <-> CISCO 2600 12.3  <-> CISCO 7500 12.2 <-> SNASW <-> M/F
------------------------------------------------------------------------------<->  CIP LAN Tok <->  M/F
CISCO 2600 Config
source-bridge ring-group 200
dlsw local-peer peer-id xxx.xxx.xxx.xxx
dlsw remote-peer 0 tcp yyy.yyy.yyy.yyy
dlsw bridge-group 30
int FastEthernet 0/1
bridge-group 30
bridge 30 protocol ieee
CISCO 7500 Config
source-bridge transparent 20 13 1 14
dlsw local-peer yyy.yyy.yyy.yyy
dlsw remote-peer 0 tcp xxx.xxx.xxx.xxx
int Channel 0/2
lan TokenRing 0
source-bridge 1 1 20
adapter 0 4000.0000.0001
int FastEthernet 5/1
bridge-group 14
bridge 14 protocol ieee
int Virtual-TokenRing0
mac-addr 4000.eeee.0002
source-bridge 25 1 20
source-bridge spanning
snasw cpname xxxx.yyyy
snasw dlus aaaaa.bbbbb
snasw port HPRIP hpr-ip FastEthernet 5/0
snasw port VTOK0 Virtual-TokenRing0 conntype-nohpr
snasw link HOSTCIP2 port HPRIP ip-dest zzz.zzz.zzz.zzz
I can connect from IBM PCOM through DLSW and CIP using mac-addr 4000.0000.0001
I can connect from IBM PCOM on local 7500 Ethernet and SNASW using mac-addr 4000.eeee.0002
I - CANNOT - connect from IBM PCOM through DLSW and SNASW using mac-addr 4000.eeee.0002
What am I missing?
mwinnett Tue, 10/26/2010 - 07:32
  • Bronze, 100 points or more
Do you still need any help for this ?
Matthew
