Installing WAAS software
May 2nd, 2010
Hi Guys,
           Appreciate if any of you could help me to solve this problem..
I've just bought WAE-7326-k9 WAE and tried to load the full image from recovery CD (download from cisco)  but during half way the program just stop with this error..
   MODEL: UNKNOWN
   FLASH: found, directory validated
  COOKIE: invalid
   IMAGE: 4.0.17.14
FLASHDEV: /dev/hda
Installer Main Menu:
    1. Configure Network (done)
    2. Manufacture flash
    3. Install flash cookie
    4. Install flash image from network
    5. Install flash image from cdrom
    6. Install flash image from disk
    7. Wipe out disks and install .bin image
    8. Exit (and reboot)
Choice [0]: 7
Enter full URL of .bin image to install.
   ftp://[user:pass@]ip_addr/path/to/file
  http://[user:pass@]ip_addr/path/to/file
  file:/local/path/to/to/file
URL for .bin image [file:/cdrom/images/WAAS40.bin]:
Continue?  This will wipe out all disks! [n]: y
- did a
- did b
- did c
- did d
- did e
- did f
- did g
- did h
- did i
- did j
- did k
- did l
- did m
- did n
- did o
- did p
- did q
- did r
- did s
- did t
- did u
- did v
sh: ifconfig: command not found
may i know what could possiblem the problem is....
Thanks in adv..
Eric Rose Mon, 05/03/2010 - 06:25
  • Cisco Employee,
Try option 2,3,5,7,8
Interesting that the model is unknown
Eric
obah Mon, 05/03/2010 - 21:33
option 2 is to prepared the  flash already done but cookie fail
option 3 fail due to unknown model
option 3-5 is just to copt sysimage to flash..
option 6 for future option..
option 7 that's where i stuck..
option 8 exit..
all tried... in fact i've tried download diff ver..result still the same..
some how the ehternet driver is not working ..i guess...that's y the error came out..
Eric Rose Tue, 05/04/2010 - 07:34
  • Cisco Employee,
Well Since option 2 and 3 failed. If you were able to install the software it wouldn't work without a valid cookie for the software to recognized.
I guess the unknown model hardware is causing an issue. MIght be a hardware issue.
obah Thu, 05/06/2010 - 00:35
I have tried to install from all  4.0.X version families still could not go through until i tried next major release Version: 4.1.3b Build: 9 then managed to install successfully..   thanks eric for the clue...
case close..
