Setting up device in DMZ (SlingBox)
SPERTWCISCO
For those who is not familiar with what is SlingBox is, it basically stream a analog or digital video source over TCP/IP.  Is a pretty cool device and it will also stream the video over internet.  http://ca.slingmedia.com/go/slingbox-prohd
The software client to view the SlingBox has a major issue.  It require that the computer and slingbox device located within the same network.  Basically, the software client will need to automatically detects the slingbox and there is no way to manually tell the software client where the slingbox is located (say if I place the slingbox in a different network).
Being side that, I try to put my slingbox in the DMZ of my ASA5505 base license. Setup static NAT as follows:
object network NAS1
host 10.2.1.10   <-----------slingbox
object network NAS1
nat (dmz,inside) static 192.168.1.15   <--------my computer
Note: I am using ASA 8.3.
My computer IP is 192.168.1.8 and when I launch the software client, it is unable to detect my slingbox in the DMZ....   Any clue how to get this going? Keep in mind I only have the base license for my ASA5505, so I can't initiate traffic from DMZ to inside and I am not sure if that is a requirement for the slingbox....
And I don't really want to put my slingbox to the inside zone, as slingbox require external internet connection initiated from the outside!
I try getting support from slingbox manufacturer, they have never seen anyone trying to do this, hence, useless...
please help!
here is my config:
: Saved
ASA Version 8.3(1)
hostname xxxxxxxx
enable password xxxxxxxxxxx encrypted
passwd xxxxxxxxxxxxxxxxxx encrypted
names
interface Vlan200
nameif outside
security-level 0
ip address dhcp setroute
interface Vlan500
no forward interface Vlan800
nameif dmz
security-level 50
ip address 10.2.1.1 255.255.255.0
interface Vlan800
nameif inside
security-level 100
interface Ethernet0/0
switchport access vlan 200
interface Ethernet0/1
switchport access vlan 500
switchport protected
interface Ethernet0/2
interface Ethernet0/3
switchport access vlan 800
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
boot system disk0:/asa831-k8.bin
ftp mode passive
clock timezone xxxxx
object network NAS1
host 10.2.1.10
object network Internet_Access
subnet 0.0.0.0 0.0.0.0
object network Internet_Access2
object-group service SlingBox tcp
port-object eq 5001
access-list outside_access_in extended deny ip any any
access-list dmz_access_in extended deny ip any any
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu dmz 1500
mtu inside 1500
ipv6 access-list inside_access_ipv6_in deny ip any any
ipv6 access-list dmz_access_ipv6_in deny ip any any
ipv6 access-list outside_access_ipv6_in deny ip any any
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-631.bin
no asdm history enable
arp timeout 14400
object network NAS1
nat (inside,outside) dynamic interface
nat (dmz,outside) dynamic interface
access-group outside_access_in in interface outside
access-group outside_access_ipv6_in in interface outside
access-group dmz_access_in in interface dmz
access-group dmz_access_ipv6_in in interface dmz
access-group inside_access_in in interface inside
access-group inside_access_ipv6_in in interface inside
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh 192.168.1.0 255.255.255.0 inside
ssh timeout 30
ssh version 2
console timeout 0
dhcpd auto_config outside
dhcpd address 10.2.1.8-10.2.1.12 dmz
dhcpd dns {ISP DNS1} {ISP DNS2} interface dmz
dhcpd enable dmz
dhcpd address 192.168.1.8-192.168.1.15 inside
dhcpd dns {ISP DNS1} {ISP DNS2} interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics host
threat-detection statistics port
threat-detection statistics protocol
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
username xxxxxx password xxxxxxxxxxxxx encrypted
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
service-policy global_policy global
prompt hostname context
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:xxxxxxxxxxxxxxxxxxxxxxxxxx
: end
Jennifer Halim
I assume you meant to say "sling box NATed ip address" instead of "my computer" on the following:
object network NAS1
object  network NAS1
If the assumption is correct, here is what I believe you are trying to achieve:
Your PC where the slingbox client is on 192.168.1.8.
Slingbox is on DMZ with ip address of 10.2.1.10, and you would like to NAT it to 192.168.1.15 on the inside.
You would also need to configure the following:
object network yourPC
     host 192.168.1.8
     nat (inside,dmz) static 192.168.1.8
Lastly, if you have access-list on the inside interface, you would need to allow between your PC 192.168.1.8 and 192.168.1.15 (plus make sure that proxy arp on the inside interface is not disabled).
Hope that helps.
^^Your assumption is correct.
I have ensure proxy arp is enable on all interface.
But still, the Slingbox client (192.168.1.8) can not detect the slingbox device (10.2.1.10) in the dmz....
Here is my current config:
: Saved
ASA Version 8.3(1)
hostname xxxx
enable password xxxxxxxxxxxxx encrypted
passwd xxxxxxxxxxxxxx encrypted
names
interface Vlan200
nameif outside
security-level 0
interface Vlan500
nameif dmz
security-level 50
interface Vlan800
nameif inside
security-level 100
ftp mode passive
clock timezone CST -6
object network NAS1
host 10.2.1.10
object network laptop
host 192.168.1.8
port-object eq 5001
access-list inside_access_in extended permit ip host 192.168.1.8 any
access-list inside_access_in extended permit tcp host 192.168.1.9 any object-group SlingBox
access-list inside_access_in extended permit ip host 192.168.1.8 host 192.168.1.15
access-list inside_access_in extended deny ip any any
pager lines 24
logging enable
mtu outside 1500
mtu dmz 1500
mtu inside 1500
arp timeout 14400
object network NAS1
http server enable
telnet timeout 5
ssh timeout 30
ssh version 2
console timeout 0
dhcpd dns [ISP DNS1] [ISP DNS2] interface dmz
dhcpd enable dmz
dhcpd dns [ISP DNS1] [ISP DNS2] interface inside
dhcpd enable inside
webvpn
username xxxxx password xxxxxxxxxx encrypted
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
call-home
profile CiscoTAC-1
  no active
: end
I have added:
access-list dmz_access_in extended permit ip host 10.2.1.10 host 192.168.1.8
but still doesn't work~
Please help!
Not too sure how slingbox works, but how does it automatically detect the server? What protocol and address does it use? Are you sure you can't configure the server ip address on the client?
