Does RVS4000 support RTSP traffic?
Answered Question
May 3rd, 2010
I can not find answer to this question from documentation.
Correct Answer by rajatsetia about 7 years 2 weeks ago
my sincere apologies, sometimes eyes see what you want them to see
RSTP is not same as RTSP, nowhere near.
ok as per my knowledge, RTSP (streaming protocol) involves client server communication on TCP/UDP port 554 and some other fundamentals where all the communication happens between client & server and router has to do what it meant to do i.e. route traffic between server & client.
It should be like any other application level protocol (http, ftp) where you need not to see if router support this protocol until unless you block traffic with some ACL or router act as mediator between server & client (proxy kind of thing).
I will see if I can get you some specific source of information. In the meantime, you may get some expert opinion from netpro community.
regards,
Overall Rating: 5 (1 ratings)
Tonttu1961 Mon, 05/03/2010 - 03:10
Thank You for quick annsver!
Just to make sure that terms are right. I was looking ansver to Real Time Streaming Protocol (RTSP). In data sheet RSTP stands for Rapid Spanning Tree Protocol (RSTP). Is this same thing?
rgds
Correct Answer
rajatsetia Mon, 05/03/2010 - 03:40
  • Bronze, 100 points or more
regards,
