Resolved: ACS4.2 ssh fails but telnet OK for same user
Apr 28th, 2010
An ACS Internal DB user cannot ssh to a 3750 switch but telnet works fine.
Authentication method is TACACS+
Other users in the same ACS user group as the problem user can both ssh and telnet to this switch OK.
Debug on the switch shows:
TPLUS: Received authen response status FAIL (3)
The ACS Failed Attempts log shows
ACS password invalid
The ACS Auth.log shows
E 3306 4384 0x27e2 Plain DB pass check for <username> failed"
for the failed username.
The 3750 switch is running 12.2(44)SE6
ACS is 4.2.0.124p11
Really puzzling that telnet using exact same user/password works fine.
Does anyone have any clues/pointers?
TIA, Graeme
Ganesh Hariharan Thu, 04/29/2010 - 00:34
E 3306 4384 0x27e2 Plain DB pass check for failed"
ACS is 4.2.0.124p11
TIA, Graeme
Hi Graeme,
For ssh connection with switch your switches should haev cryptographic image with K9 in ios,then only you can ssh the switch.
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
GRAEME DANIELSON Thu, 04/29/2010 - 22:28
Ganesh,  thanks for taking the time to respond but it doesn't help at all...
Javier Henderson Fri, 04/30/2010 - 09:24
Try removing the user from ACS and re-adding it.
Also, does the user have any special characters in its password? If so, try changing it to something using just letters and numbers, as a troubleshooting step.
GRAEME DANIELSON Mon, 05/03/2010 - 00:41
The password has a mix of upper case lower case and numbers - no special characters. I resolved by re-entering the same password into ACS. Strange.
