05-03-2010 12:47 AM - edited 03-11-2019 10:39 AM
I am looking for the way to define QoS policy on ASA 5520 only from 8:00 till 16:00
We use Cisco security manager and cannot find option to specify time interval.
I didn't find such option in ASDM as well
Can you help me?
Thanks, Igor
05-03-2010 03:42 AM
Yes, you can use time range ACL to match the traffic, and apply the QoS accordingly.
05-03-2010 01:57 PM
Here is an example https://supportforums.cisco.com/docs/DOC-1230
And in the ACLs, as halijen said you should use the time range option.
I hope it helps.
PK
05-03-2010 10:51 PM
but how I can define time range ACL in Cisco security manger ?
05-04-2010 02:28 AM
On CSM: Firewall --> Access Rules --> Add a new ACL/ACE --> click on the "Advanced" button --> there would be "Time Range" option to configure time range.
05-04-2010 02:59 AM
Thanks for the answer
Probably I misunderstand something
You wrote about time range in Access rule, and I really see this option in Access rule in CSM
But when I define QoS - I define Access control list, Traffic flow and then I define QoS in
CSM --> PIX/ASA/FWSM Platform --> Service Policy Rules --> IPS, QoS and Connections Rules
And I didn't find option to define time range not in ACL, not in Traffic flow and not in QoS options
05-04-2010 04:04 AM
You are absolutely right. I have just double checked that in the lab, and there is no time-range option for QoS on CSM.
You might want to open a TAC case for that.
