VWIC2-2MFT-T1/E1 and ppp encapsulation
ssieger
is it possible to run ppp encapsulation with a VWIC2-2MFT-T1/E1 interface?
Tia,
Stephan
6 Replies 6
paolo bevilacqua
Yes, of course.
Ok, i'll refine my question. How can i configure ppp encapsulation on  VWIC2-2MFT-T1/E1 with IOS advipservicesk9-mz.124-17a? If i paste the command encapsulatio ppp i get %Hardware does not support the encapsulation. I got many information that the VWIV ist able to run with ppp, but obviously it requires something more.
Hope somebody knows the answer.
Stephan
What? It Cann't Be!
Let me show you some config:(this router use ipbase ios,and it is running)
card type e1 0 0
controller E1 0/0/0
clock source internal
channel-group 0 unframed
interface Serial0/0/0:0
description toHQ
ip address 10.1.1.2 255.255.255.252
encapsulation ppp
load-interval 30
you should chek your config .
Try the following
http://www.cisco.com/en/US/docs/ios/12_4t/12_4t11/intserv.html#wp1050939
Otherwise use the specific data cards for ISDN calls.
you can use ppp or hdlc(hdlc is default option) encapsulation .
when two sides use the same encapsulation option,anyone can go.
Ok, here are the parts of my config:
card type e1 0 0
isdn switch-type primary-net5
voice-card 0
no dspfarm
dsp services dspfarm
username XXX password XXX
controller E1 0/0/0
pri-group timeslots 1-31
description *** Voice ***
controller E1 0/0/1
description *** ISDN-Backup ***
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
interface Serial0/0/1:15
description *** ISDN-Backup Arcor ***
no ip address
encapsulation hdlc
dialer pool-member 2
no snmp trap link-status
isdn answer1 xxxxxxx
isdn calling-number xxxxxxx
isdn sending-complete
interface Dialer100
ip address 10.x.xxx.xx 255.255.255.254
encapsulation ppp
ip summary-address eigrp 597 10.x.xxx.xx 255.255.252.0
dialer pool 2
dialer remote-name xxxxx
dialer string xxxxxxxxxxxxxx
dialer hold-queue 5
dialer load-threshold 40 either
dialer-group 1
ppp authentication chap
voice-port 0/0/0:15
voice-port 0/0/1:15
Port 0/0/0 is configured for voice, and 0/0/1 should be configured for isdn backup.
