ASA 5520 - DRAM Upgrade 2Gbyte
May 3rd, 2010
Hello
could somebody tell me please,  if you already encountered the following  issue :
To upgrade the ASA 5520 from 8.0 to 8.3 we need a Dram upgrade .
To do this we need the following Memory Kit: ASA5520-MEM-2GB=.
Our ASA 5520 though posses  only one DRAM Slot on the  motherboard .
On the Cisco TAC ,  the ASA documentation I have found , always mention four slots on the ASA
for this upgrade.  But our ASA5520 has only one slot. The other three are not solded.
Is there any information about,  from which ASA  H/W release  are the other
three slots present on the mainboard.
Please see attached . "show Version"
Thank you . I`ll really apriciate it if someone could give me a hint about this issue.
Panos Kampanakis Mon, 05/03/2010 - 13:56
Old 5510 models had 4 slots.
You should use the one that you have or the first of the four (that your current RAM is in), where applicable.
PK
Panos Kampanakis Mon, 05/03/2010 - 17:14
To avoid confusion my previous comment was refering to a 5510, I did not notice that we were dealing with a 5520.
Indeed as Andrew mentioned the 5520s should have 4 slots. So, this should be tracked through a case with TAC.
PK
rayborg Tue, 05/04/2010 - 00:09
Thank you guys for your prompt answer.
This unit happens to be in our Lab and we do not have a Smartnet for this unit.
It seems that I have lost by now although,  i think that  this is a matter of general interest and it shoud be followed up by TAC
as a general info for all ASA 5520 customers.
Thanks again.
Panos Kampanakis Tue, 05/04/2010 - 08:48
It has been seen once again and is being traced down now.
It would be nice if your could be added through a TAC case.
PK
Andrew Ossipov Mon, 05/03/2010 - 14:15
PK, we're dealing with an ASA5520 that should always have 4 DIMM slots. This issue should be tracked through a TAC case.
