ACS Replication is not happening
May 3rd, 2010
Gents,
we have two ACS 4.2 for Windows. We moved to them from ACS SE 4.1. I restored all backups to ACS 4.2 and tried to setup replication, but it is not happening. I already checked through troubleshooting guide and seems like everything is configured properly.
In Master Server I can see record "Outbound replication cycle starting...", but it is the only record I can see in logs. At Slave Server there are no records at all. I also checked network connectivity between servers by telnetting to port 2000 - works fine. So it seems something wrong in ACS. Where can I collect additional data for troubleshooting?
Thanks a lot
agipkcolon Mon, 05/03/2010 - 03:51
just tried to sniff traffic at master server. Can't see any packets sent to slave server. Any ideas?
agipkcolon Mon, 05/03/2010 - 04:50
Additional Info - I could make it work, but I had to remove at Master Server all SEND check-boxes in Replication Components table except Network Configuration. Replication went fine. Then I added another replication component and tested replication. it worked until I enabled Password validation settings to be sent and then it stopped working. Removing this component didn't help to run replication. I had to remove all components again, replicate database and then add all components back, except Password validation settings component.
is it bug?
agipkcolon Mon, 05/03/2010 - 07:45
Unfortunately we don't have smartnet for ACS. So I think I am unable to create a case in TAC.
What is the CISCO's approach to product's bug that can't be reported due to absence of Support Contract?
