05-03-2010 03:21 AM - edited 03-15-2019 10:35 PM
Hi all,
I have a CME 8.0 installation with a 7962 and a 7915 connected to it.
Everything works fine but the 7915 does not light, when it boots it lights the backlight but turns it off again and shows the configured buttons but very dark.
Is there anything I can change?
Lastest firmware installed (9.0.2 on 7962 and 1.0.4 on 7915)
Many thanks
Solved! Go to Solution.
05-03-2010 03:57 AM
You can control the contrast of the 7915 module from the IP phone.
1. Settings
2. User Preferences
3. Contrast
4. Choose the option for your 7915, which should be option 2 "Expansion Module 1 (7915)"
Once you adjust and save, it should stick. No configs needed on CME.
HTH.
Bill
Please remember to rate helpful posts.
05-03-2010 03:57 AM
1. Settings
2. User Preferences
3. Contrast
HTH.
Bill
05-03-2010 04:11 AM
I'm feeling stupid... I looked for 2 days and no answer anywhere...
Many thanks
