Unable to do ip routing in cisco 3550 switch : IOS c3500XL-c3h2s-mz-112.8.2-SA6.bin
Hi Dudes,
I have CISCO 3550 switch, which is having IOS c3500XL-c3h2s-mz-112.8.2-SA6.bin. I tried to enable the " IP Routing" but coudn't. can any one help me.
Tamilvanan.S
5 Replies 5
Reza Sharifi
Even with SMI image you should be able to run RIP version 1 and 2 and static routes.
What is the error message?
Reza
Jon Marshall
That's a strange IOS version, are you sure you have a 3550 switch and not a 3524xl switch ?
Jon
Giuseppe Larosa
Hello Tamilvanan,
Jon is right: IOS filename leads to a C3500XL that is a L2 only switch and this would explain why it complains of your attempt to turn  ip routing on
Hope to help
Giuseppe
Leo Laohoo
Catalyst 3500XL-EN is a layer 2-only switch.  The 3550 "will" support IP routing:  RIPv1, RIPv2 and IS-IS.  If you upgrade to Enhance Multi-layer switch Image (EMI), it will support the rest.  Upgrade of the 3550 is via a hardware (integrated circuit) method only.
Don't forget to rate our posts.  Thanks.
Ganesh Hariharan
Hi Dudes,
Tamilvanan.S
Hi Tamilvanan,
Check out the realease note for c3500XL-c3h2s-mz-112.8.2-SA6.bin
http://www.cisco.com/en/US/docs/switches/lan/catalyst2900xl_3500xl/releasesa6/rn/1036901.html#wp17717
Hope to Help !!
Ganesh.H
