Unable to establish VPN connection on rv016 router through QuickVPN
May 3rd, 2010
We have an RV016 router with a VPN tunnel configured for remote access called Home. I installed the QuickVPN software that came with the router and tried to establish a connection. I get an error right away stating that a connection couldn't be established and lists some probable problems. I downloaded the latest QuckVPN application and again tried to get a connection and get the same problem. When I check the wget_error file it says bad port number. I have the software configured to use Auto for the port number. I also disabled the firewall as suggested and still the same error. It's an XP client with SP3. Is there a way to tell what port the tunnel is using and maybe set that port number and maybe get a connection?
spnelson1 Mon, 05/03/2010 - 07:26
I was able to start a connection but I get the message that the server's certificate does not exist on the local computer. I did copy the pem file to the Program Files\Cisco Small Business\QuickVPN Clent directory. Is there another file it is looking for?
cchamorr Mon, 05/10/2010 - 17:57
  • Silver, 250 points or more
Ok, try to do the following:
- Go to the VPN clien Accounts and generate a new certificate, DO NOT EXPORT IT.
- On the local machine, remove the previous certificate.
- Try to connect again, you will see a warning message in regards to the certificate, hit NO and continue.
Hopefully that will get it to work.
spnelson1 Tue, 05/11/2010 - 12:57
Thanks for getting back to me. I tried what you suggested but I still have
the same error.
Scott Nelson
IT Manager
Birchland Plywood-Veneer Ltd
PO Box 430
Thessalon, ON
Canada
P0R 1L0
(705)842-2430 x238
