05-03-2010 07:27 AM - edited 03-10-2019 05:06 PM
After I upgraded the ACS to 4.2.0.124 it began showing the error below from time to time on the agent. It stops authenticating some users and after 50 minutes it the stops authentincating all of them. I tried to Restart all services on ACS but it did not work and it just works when I reload the ACS appliance.
NTLIB: Unable to get info from RootDSE - check Active Directory availability [-2147016689, 1197]
NTLIB: Unable to get info from RootDSE - check Active Directory availability [-2147016646, 1197]
NTLIB: ad_FindUser failed because Active Directory is not available [1744]
RPC: NT_DSAuthoriseUser reply sent
RPC: NT_DSAuthoriseUser received
NTLIB: Loading Domain Cache
05-03-2010 07:30 AM
You said you rebooted the ACS appliance, so I assume you are running the ACS SE. Does the version of the Remote Agent match the version of ACS?
05-03-2010 09:14 AM
Yes, the remote agent is also running version 4.2.0.124.
