Cannot return back to Cisco 2511 after telnet?
May 3rd, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
I have CCIE lab at home (14 Cisco routers/switches). I am using Cisco 2511 as terminal (serial) server for accessing all other devices’ console. The loopback IP address has been created; ip host R4 on 8th port has been defined. I am able to connect to router R4 but I cannot return back to Cisco 2511. The same result is for every router on every port...
TermServer#R4
Trying R4 (172.21.1.1, 2008)... Open
Router>
Router>
Router>
Router>
Router>exit
Router con0 is now available
Press RETURN to get started.
Router>exit
It seems like sequence Ctr Shift 6 x doesn’t work. I tried with Secure CRT, Putty on Vista and Hyper terminal on XP but the outcome was always the same…This is the configuration of 2511.
TermServer#sh run
TermServer#sh running-config
Building configuration...
Current configuration:
version 12.0
service timestamps debug uptime
service timestamps log uptime
hostname TermServer
ip subnet-zero
ip host R4 2008 172.21.1.1
interface Loopback1
ip address 172.21.1.1 255.0.0.0
no ip directed-broadcast
interface Ethernet0
no ip address
shutdown
interface Serial0
no ip address
no ip mroute-cache
shutdown
interface Serial1
no ip address
shutdown
ip classless
line con 0
transport input none
line 1 16
session-timeout 1
no exec
transport preferred none
transport input all
line aux 0
line vty 0 4
End
After 1 minute the session is auto terminated because of session-timeout 1 command.
Any suggestion what might be a problem?
Reza Sharifi Mon, 05/03/2010 - 13:48
  • Cisco Designated VIP,
    2017 LAN
Hi Franjo,
In your example, after login to R4 if you want to get back to the 2511, hold down "ctrl+shift+6" at the same time than "x".
Reza
Franjo Pongrac Tue, 05/04/2010 - 00:23
Hi Reza,
I tried with small pause between Ctrl-Shift-6 and X but nothing has happened... I tried this with English keyboard.
Thanks anyway.
Ganesh Hariharan Mon, 05/03/2010 - 22:41
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
TermServer#R4
Router>
Router>
Router>
Router>
Router>exit
Router>exit
TermServer#sh run
version 12.0
hostname TermServer
ip subnet-zero
interface Loopback1
interface Ethernet0
no ip address
shutdown
interface Serial0
no ip address
no ip mroute-cache
shutdown
interface Serial1
no ip address
shutdown
ip classless
line con 0
line 1 16
session-timeout 1
no exec
transport input all
line aux 0
line vty 0 4
End
Check out the below link !!
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_configuration_example09186a008014f8e7.shtml
Hope to Help !!
Ganesh.H
Franjo Pongrac Tue, 05/04/2010 - 00:27
Hi Ganesh,
The proposed document (link) is exactly the one which I followed when I was configuring.
Thx.
Franjo
Ganesh Hariharan Tue, 05/04/2010 - 00:50
Hi Ganesh,
Thx.
Franjo
Hi Franjo,
In order to come back to terminal server from existing session by using ctrl-shift-6-x to bring you back to terminal server.what error it shows when you press this command.
Ganesh.H
Franjo Pongrac Tue, 05/04/2010 - 01:03
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi Ganesh
There is no any error. It simply doesn’t react. Like I didn’t type anything… Please check the log file attached. Can you see those blank lines; these are the moments when I typed Ctrl-Shit-6, x sequence.
Thanks for helping me!
Franjo
