2651 router upgrade failure - not enough space
May 3rd, 2010
I have c2600-i-mz.123-26.bin running.  If I attempt to upgrade to it IP Plus version I get the following:
Erasing device... eeeeeeeee  ...NOT erased
Erase of flash: complete
loading c2600-is-mz.123-26.bin: !!!!!!
%Error copying flash:c2600-is-mz.123-26.bin (No space left on device)
The requirement for this IOS is 32MB, which I have, but it doesn't seem to work properly.
I tried to squeeze the flash, but get the following:
First create squeeze log by erasing the entire device  -NOT SURE HOW TO DO THIS WITH A PRODUCTION ROUTER-
%Error squeezing flash (Missing or corrupted log)
Is the memory bad?  Why the NOT erased message?
Any assistance would be appreciated!
Version Information:
IOS (tm) C2600 Software (C2600-I-M), Version 12.3(26), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by cisco Systems, Inc.
Compiled Mon 17-Mar-08 15:23 by dchih
ROM: System Bootstrap, Version 12.2(10r)1, RELEASE SOFTWARE (fc1)
Router uptime is 2 hours, 55 minutes
System image file is "flash:c2600-i-mz.123-26.bin"
cisco 2651 (MPC860P) processor (revision 0x200) with 126976K/4096K bytes of memory.
Processor board ID JAB05160ASL (2887752866)
M860 processor: part number 5, mask 1
Bridging software.
X.25 software, Version 3.0.0.
2 FastEthernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
32K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
Overall Rating: 1 (1 ratings)
stonnet72 Mon, 05/03/2010 - 12:55
To be on the safe side, you might want to back up your configs before you decide to format. Most important rule to be followed with Networking devices.
Paolo Bevilacqua Mon, 05/03/2010 - 13:16
Cisco does not store config on flash.
smitesh kharecha Mon, 05/03/2010 - 20:59
Flash might be faulty.
Try formatting the flash card and if it gives you error, then try to remove and reinsert it (flash card are hot swappable).
After you have re-inserted flash card, again try to format it. If it still gives you error; probably flash card might be faulty.
And if it doesn't gives you error, VOILA.. u got your flash clean. Time to upgrade it with the new IOS.
Paolo Bevilacqua Tue, 05/04/2010 - 04:54
Incorrect, 2600 routers except 2691, have internal flash module, not CF.
mkoncurat Tue, 05/04/2010 - 06:58
Thanks for all the response!
Squeeze flash results in the following error: %Error squeezing flash (Missing or corrupted log)
Format flash is invalid on this device.
Erase flash produces the NOT ERASED message.
The flash is internal on this unit.  I'm assuming it's not hot swapable.
bgandhi Wed, 05/05/2010 - 01:33
Sugegst you try loading the image from xmodem(console). this will automatically erase the flash and load image but your router would be down atleast for an hour at a speed of 115200.
shailesh.h Wed, 05/05/2010 - 05:49
  1. check flash space with command 'Router#show flash' http://www.cisco.com/en/US/products/sw/iosswrel/ps1834/products_tech_note09186a00800fb9d9.shtml
  2. Follow steps Refer http://www.ciscopros.info/en/US/docs/ios/12_2/configfun/configuration/guide/fcf006_ps1835_TSD_Products_Configuration_Guide_Chapter.html
    • Delete unwanted files in flash partition -- delete command
    • Erase files from Flash Partition - Erase command
    • Format - to complete cleanup the flash data
This will help you to check how many flash partitions you have, are there any unwanted files in the flash dir and facilitate for clearing the space.
Hope this will make you happy to progress
mkoncurat Wed, 05/05/2010 - 09:48
I'm not sure who rated your post, but it wasn't me...  It's actually quite helpful.
mkoncurat Wed, 05/05/2010 - 09:50
I'm assuming the flash is bad.  I've ordered a replacement module to try.  I'd rather not replace a router that is 100% reliable.
