New Secondary ASA install process question
May 3rd, 2010
Hello
I have 2 asa 5550's v8.2 in an active/standby config, our secondary failed and we have a new RMA unit from cisco.  After MUCH stress from tac getting the right feature set on it I am taking another stab tomorrow morning using the following procedure.
Commands on primary
failover (is currently disabled)
Commands on secodary
failover lan interface fail g1/0
failover interface ip fail 192.168.25.2 255.255.255.248 standby 192.168.25.2
int g1/0 no shut
failover lan unit secondary
failover
copy run start
Question, in v8.2 do I need to run a "write standby"?
Going off of http://www.cisco.com/en/US/docs/security/asa/asa82/configuration/guide/ha_active_standby.html#wp1107287 I dont see a write standby in there as part of the secondary procedure.
Also, if this is a production firewall will this disrupt traffic on the primary unit even if the intention is the primary will stay the primary?
thanks
e-
Overall Rating: 5 (2 ratings)
Federico Coto F... Mon, 05/03/2010 - 09:02
  • Green, 3000 points or more
The ''write standby'' is only if you manually want to synchronize the active configuration to the standby unit. It is not mandatory.
Federico.
Jon Marshall Mon, 05/03/2010 - 12:24
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
No it should not affect the primary firewall even if you issue a write standby altho as Federico says you don't actually need to. As always if possible do this out of core production hours.
Jon
