Natting on router based on destination
Answered Question
May 3rd, 2010
  • Silver, 250 points or more
Hi ,
            I need to perform dynamic natting based on destination ip address , Similary let me know whether i can have multiple dynamic natting in cisco router .
              In my setup i need to use mutiple dynamic nat  becoz client has given access to  the apllication server based on my  NAT IP address pool  ..
pasting u sample config
interface FastEthernet0/1
ip address 172.16.1.1 255.255.255.0
ip nat inside
interface Serial0/0/0
ip address 10.10.10.2 255.255.255.252
ip nat outside
ip nat pool dev 10.10.10.9 10.10.10.11 netmask 255.255.255.252
ip nat pool prod 10.10.10.12 10.10.10.15 netmask 255.255.255.252
ip nat inside source list 101 pool dev
ip nat inside source list 102 pool prod
ip classless
access-list 101 permit ip 172.16.1.0 0.0.0.255 host 20.20.20.1
access-list 102 permit ip 172.21.16.0 0.0.0.255 host 30.30.30.1
If am wrong in my commands please write back ..thank you..
Correct Answer by Jon Marshall about 6 years 11 months ago
Yes you can have multiple NAT pools on IOS and your config looks fine. Have you tested it yet ?
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Mon, 05/03/2010 - 09:52
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jon
SANTHOSHKUMAR S... Mon, 05/03/2010 - 10:02
Thanx Jon much , I havent tested , prepared config from lab router ..once i have tested i ll let you know ..
  I am always impressive with your answer which u used explain with clear concept n fundas , keep rocking !!!!!!!!!!!!!!!!!!!!
