upgrading IOS
Answered Question
May 3rd, 2010
How do you upgrade the IOS on
2960 switch, 2821 router and ASA5510 firewall.  Are the procedures the same? Do you need a SMART Net contract on the devices to upgrade the IOS? The switch needs SSH to be configured, thus from the base IOS on the switch, how do I find the switch IOS that has SSH capabilities.
Thanks..
Correct Answer by Reza Sharifi about 7 years 1 month ago
Said,
The procedure is pretty much the same for switches and routes.  As for the ASA, you can use cli or ASDM to upgrade the IOS.
Here is a link to it;
Reza
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a008067e9f9.shtml
Yes, you need a Smart Net contrat to be able to download the IOS.  If you need SSH than look for an IOS that has k9 in the name
see example below:
c2800nm-adventerprisek9_ivs-mz.124-3g.bin
Reza
Overall Rating: 5 (2 ratings)
Correct Answer
Reza Sharifi Mon, 05/03/2010 - 13:42
  • Cisco Designated VIP,
    2017 LAN
see example below:
Reza
saidfarah Mon, 05/03/2010 - 13:48
Reza,
Is the procedure the same for the router, switch and ASA firewall? Download the IOS to TFTP server on the network and then copy the IOS to the device?
On the router > Download the file to a TFTP server on the network > copy TFTP flash ?
Thanks.
Said
