UC Voice enabled directory Handler
May 3rd, 2010
I'm trying to setup a voice enabled directory handler in Unity connection 7.1.3.
I have all configured and seem to work ok except one issue.
I can only call subscribers by Name, i can not call ext and other numbers example outbound calls. when i try to call i get  "you can not call that number....."
Any idea to what it could be?
Mohammed
Overall Rating: 3 (1 ratings)
David Hailey Mon, 05/03/2010 - 22:11
2 questions:
1) Do you have that callers can enter extensions during greeting selected?
2) What restriction tables are applied to your system?
Hailey
Please rate helpful posts!
mnour401917_2 Mon, 05/03/2010 - 23:37
David,
It was a restriction Table. now i can call external numbers
Mohammed
