NAT outbound SMTP
Answered Question
May 3rd, 2010
Ladies and Gents,
I have 3 interfaces in my PIX, Inside, Public and DMZ. I have a host (192.168.1.111) in the DMZ that needs to relay mail to a smart host on the internet. However, the smart host only accepts connections from certain addresses. Public interface's address is one of them. So I've set up an ACL, applied it to the interface.
access-list DMZ_access_in extended permit tcp host 192.168.1.111 eq smtp object-group smarthostcluster eq smtp
access-group DMZ_access_in in interface DMZ
Now I have to NAT/PAT the traffic, since the smart host only accepts connections from the Public interface.
global (Public) 1 interface
nat (DMZ) 1 192.168.1.111 255.255.255.255
However, it still doesn't work. It says connection is refused. So, I wonder if I have missed something. Our main server sends out fine, but the Inside ACL is a lot less restrictive so I really don't know who's at fault, me or the smart host.
Igs
Correct Answer by bhisham84 about 6 years 8 months ago
access-list DMZ_access_in extended permit tcp host 192.168.1.111 object-group smarthostcluster eq smtp
Try this hope this will work...!
Thanks/Bhisham
Overall Rating: 5 (1 ratings)
Correct Answer
bhisham84 Mon, 05/03/2010 - 23:50
Thanks/Bhisham
zulu-5-2010 Mon, 05/03/2010 - 23:55
Bhisham, thank you for your help. Greatly appriciated.
I'll change the line tomorrow, see what happens
