CUPC log in unsuccessful
eddchen
Hi guys,
cupc was working fine, version is: 7.0.2
getting error: login failed, Make sure your username and password are correct
same password working to get in cucm user and cup user
log file from cupc provided below. Not sure what is wrong here.
Thx
5 Replies 5
htluo
Level 9
Level 9
Can you set "Client Profile Agent" trace to debug level?  Recreate problem and get the "Client Profile Agent" logs from CUPS.
Michael
http://htluo.blogspot.com
Thx guys, below is the log captured from cups
1) How many CUPS server in the cluster?
2) How many CUPS server used to be in the cluster?
3) Is "CUP-AMS-011" resolved to 144.254.210.27 from the CUPC computer?
Michael
Hi Michael,
Thx and please find the reply below:
    There are 4 of them, cup-ams-011 012 013 and 013, and trace file provided earlier are checked for all of them and only 011 generated report
    it has been four ever since i starting to support
    yes, nslookup returns 144.254.210.27
cheers,
ed
Has this user ever been able to log in before?  With that version of CUPS we ran into a database synchronization problem caused by a bug; if any user had the same number set as their primary extension and ther IPCC extension, the username and info would synch, but the password would not.  And it manifested just like the symptom you describe; User account is there and looks fine, password works in CCMUser, but doesn't on CUPC.
