pri link ip address
Answered Question
May 3rd, 2010
Hi Guys,
I just wondering, which IP address on RouterD should I include on "session target ipv4" if for example:
RouterA would like to call RouterF, how do you direct the call to using the "PRI link" on RouterB >> RouterE >> RouterF? instead of going to RouterB >> RouterC >> RouterF as RouterC is set only for "backup link" incase if the "PRI link" is down.
eigrp/ospf routing protocol apply in this configuration....
RouterA--------------------RouterB------------------RouterC-|
      10.0.0.1           10.0.0.2  |   10.0.0.3         10.0.0.4      | 10.0.0.9
                                                 | (pri link - cloud)                  |(back up link)
RouterD-------------------RouterE-------------------RouterF-| 10.0.0.10
      10.0.0.5             10.0.0.6      10.0.0.7         10.0.0.8
Thanks in advance,
Terrence
Correct Answer by William Bell about 7 years 1 month ago
You don't need to create a loopback it is just a recommendation. What you need to do is bind your call control and media to a specific interface. A loopback is recommended because it is a logical interface and, as such, is not subjected to link failures that could occur on a physical interface. In your diagram (which may change for the next question) RouterD may have just one link. So, one may say "hey, since it has one link I will just use that link.". That could be true, but when you put together a design for a real life situation, you want to make sure you apply a design aspect such as IP address allocation, the use of loopback, call signaling protocol, etc. etc. across all components. At least as much as possible.
So, is it required: no. Is it recommended? By me - yes.
HTH.
Bill
Overall Rating: 4.3 (3 ratings)
James Hawkins Tue, 05/04/2010 - 03:57
  • Blue, 1500 points or more
Set up a loopback interface on router F and use the IP address assigned to
it as the target. Enable a dynamic routing protocol and Bob's your uncle.
vip80y_cisco Tue, 05/04/2010 - 05:59
Thanks James and thanks again William for your reply
but what happens if RouterA would like to call RouterD, so RouterA >> RouterB >> RouterE >> RouterD. Do I need to create a loopback int as well for RouterD?
Cheers,
Terrence
Correct Answer
William Bell Tue, 05/04/2010 - 07:55
  • Purple, 4500 points or more
HTH.
Bill
