PBR with SLA track
May 4th, 2010
Hi, I have 2 ISPs and I would like to navigate through one of them (ISP1) until the performance of the line is falling down (for example, I can test an Internet DNS server for icmp-echo > 200 ms), then I have to route to ISP2 until the perfomance on ISP1 is back
I have done this configuration:
ip sla 1
icmp-echo ip_internet
timeout 200
frecuency 30
ip sla schedule 1 start-time now life forever
track 1 rtr 1 reachability
ip route track 1
ip route Dialer1 10
My problem is that when track fails the router changes the route to ISP2, but in this moment the icmp-echo to an internet server its ok again through the new ISP2, so it changes the route again to ISP1, then track fails and changes to ISP 2, and so on.
How can I avoid that? I would like to track the Internet Server always through ISP1, not through the default route in that moment. Is this possible?
Is there a solution
Overall Rating: 4 (2 ratings)
Giuseppe Larosa Tue, 05/04/2010 - 04:39
Hello Jmprats,
I would consider to track IP reachability of an ISP1 public address, rather then checking a public DNS server somewhere in the Internet
The way you have built the test causes this bouncing effect
Hope to help
jmprats Tue, 05/04/2010 - 04:54
Yes, but ISP1 public Ip addressess are available from ISP2 too
, so when I'm tracking them from ISP2 I will have the same effect (a continous change of the default route)
paul.basford Tue, 05/04/2010 - 04:54
Also, I would add a static route to the IP address you are monitoring with the SLA to make sure it always goes
via ISP1. e.g -
ip route ip_internet       (i'm assuming this is ISP1 from your config)
Related Content
