LMS 3.2 with HUM 1.2.1 Interface Utilization Report
May 4th, 2010
Hi all!
We are having a problem with  the output of the "Interface Utilization Report" of the Health and  Utilization Monitor V1.2.1.
Some Interfaces have an "Rx Max%" and  "Tx Max%" above 100%. That can not be correct.
Here are two  samples of the output (It is a weekly report):
Interface   Rx Max%   * Rx  Avg%   Rx Min%   Tx Max%   * Tx Avg%   Tx Min%
Gi0/5           471.39          8.70          0.00         1295.33        12.81         0.09
Gi0/22        1312.45       13.11          0.03           338.69          6.79        0.00
What can be the cause for this output?
Thank you!
Joe Clarke Tue, 05/04/2010 - 23:35
Have these ports changed speed since HUM initially discovered them?  That is, were they originally added when they were 100Mbps, and are now operating at 1 Gbps?  If you monitor the ports using the Live GraphIt portlet, do you see the 100%+ spikes occurring still?
stephenweinand Thu, 05/06/2010 - 04:47
No, the speed has not changed, it always was 1000 MBit/s.
I also not see any spikes in the Live GraphIt portlet.
Maybe I should rebuild the report and wait if these things are still occuring?
Joe Clarke Thu, 05/06/2010 - 22:44
That is a good idea.  If you can still reproduce the problem, getting the upm_process.log with appropriate debugging should show how the utilization is being calculated.
stephenweinand Thu, 05/06/2010 - 23:33
I have created a new weekly report, so I have to wait, if it is getting better now.
I will let you know.
stephenweinand Sun, 05/09/2010 - 23:34
So, the new weekly report does not show the high Utilizations anymore, but there is a new problem:
In the "Report Details", there are 7 devices and 126 interfaces, but in the "Interface Utilization Summary", there are only 49 Interfaces.
I have added a screenshot, so that you can see, what I mean.
Joe Clarke Mon, 05/10/2010 - 07:43
Do you see any errors in your poller relating to these other interfaces?
Joe Clarke Wed, 05/12/2010 - 13:30
It appears you're running a copy of the Interface Utilization Quick Report.  If you run the built-in Quick Report, does it show all of the interfaces?
stephenweinand Thu, 05/13/2010 - 23:27
When running the build in Interface Utilization Quick Report, there are shown 27 of 126 Interfaces.
It seems, that the number of Interfaces changes every day, when running the report.
