CVP - Run Ext. Script Node Querry
May 4th, 2010
I was trying to route the call towards VXML app using Run Ext. Script Node.
I referred cisco configuration doc. and it states that you need to set the VRU Script name as  GS,Server,V
My question is once i configure this script in network VRU script list and associate it with Network VRU (type10).
Do i need to create any VRU script elsewhere with the same name ? or it will default route the call to the Call Server ?
Thanks in anticipation
mehtdi1980 Tue, 05/04/2010 - 06:50
Hi geoff
Thanks for the response.
I understand you need to set the application name = "" in the variable and pass it to the VRU .
But my querry is when we set the Run External script Node = GS,Server,V ( VRU Script name )
Do we create this VRU Script elsewhere apart from ICM . In ICM i am aware that you need to create this in Network VRU List.
Hope my question is clear
david.macias Tue, 05/04/2010 - 06:58
  • Blue, 1500 points or more
The Network VRU Script is only created in ICM.
david
mehtdi1980 Tue, 05/04/2010 - 07:17
Thanks David.
Reason being i asked is because in when ICM is integrated with UCCX/IPIVR, you need have the same script in UCCX server as well .
Just wanted to make sure that in CVP its unlike UCCX , where the VRU script is only created on ICM
david.macias Tue, 05/04/2010 - 07:22
CVP is nothing like IP IVR.
david
