WLC4402 - No keyboard input via console
Answered Question
May 4th, 2010
I try to configure a WLC4402 new out of the box. If I make a console connection for initial configuration I see the boot sequence in my terminal software but I am not able to send keyboard commands. the session does not accept keyboard input. I tried to do this with different PC's, different serial ports and different cables, including the supplied console cable. I have been testing with other devices (cisco router on console cable) and with these devices everything works fine. Only the WLC4402 gives me trouble. Any advice? Thank you.
Correct Answer by dancampb about 7 years 2 months ago
Make sure that flow control is disabled on your terminal emulation program.  Having flow control enabled will cause the exact issue you are describing.
Overall Rating: 5 (2 ratings)
Correct Answer
dancampb Tue, 05/04/2010 - 07:47
  • Cisco Employee,
Related Content
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
