ESX Etherchannels to 2148s
Answered Question
My customer has 2 N5ks and 4 2148s.  The N5ks have VPC between them, and the 2148s are single-homed, 2 to each N5K.  Am I corect in saying that an ESX box with a 4GB host etherchannel would have one connection to each 2148, and that the ports would be configured in a chennel-group on each N5K, and in a VPC instance between the 5Ks?
Thankls
Correct Answer by Lucien Avramov about 6 years 8 months ago
Well, in this case, I would preferably suggest you to even use the Nexus 1000v if you want to scale with all the vm's.
Otherwise the vswitch is fine too.
Under vswitch, bundle the 2 uplinks together (port-channel).
And physically have one to each FEX, that is how VPC will work.
Overall Rating: 5 (1 ratings)
Lucien,
Thank you for your response.  I am familiar with the doc you ponted me to.  My question was, since the doc only shows a single connection to each of the N5Ks, I wanted to be sure that if I had 4 server connections in a channel, that I could home one connection to each of 4 2148s, then home 2 of the 2148s to each N5K, and define a channel group on each N5K with 2 members in the group, then put the port channel in a vpc to get 4GB total.  I know the 2148s can only have a single connection each, but I was hoping the N5Ks could aggregate them.  The config would look like this:
int eth 100/1/1            First 2148
channel-group 10
int eth 101/1               Second 2148
channel-group 10
int port-channel 10      N5K VPC to peer with identical config
vpc 10
I think as long as there is only 1 link per 2148, I'm OK, but I want to be sure, due to the rather sevre limitations imposed by the 2148s.
Mike Flanigan
Lucien Avramov Thu, 05/06/2010 - 09:23
Mike, that will be a no go. your first pair of N5K vpc would need to have a vpc peer link with the other pair of N5K vpc to communicate and avoid loops and this is not possible.
4 FEXs going to only 2 N5K wont work either and that's a FEX limitation.
The 2248 will support multiple ports to one server so you will be able to have 2 times 2 links to 2 fexs.
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
Lucien,
Thanks again.  I believe I understand your answer - I'll need to get with the custimer.  Am I right then in saying that the ESX vswitch could be configured to support 2 2GB channels,instead of a single 4GB channel, each channel with a single connection to a 2148?  That is in accordance with the diagrams.  The 2148s would see the 2 ESX channels as separate hosts.  Can you confirm this?
Mike Flanigan
Correct Answer
Lucien Avramov Thu, 05/06/2010 - 12:55
