CUCBE operating on Demo licenses
May 4th, 2010
Hi Guys,,
This is my first time installing Business Edition, I had installed all the license files (CM7-PAK and UNITYCN7-BE-PAK)
But it shows the following:
Licensing Warnings:
System is  operating on Demo licenses. Please upload relevant license  files.
I also attached the License Unit Report screen shoot.
What i miss here...?
Okok
William Bell Tue, 05/04/2010 - 07:23
  • Purple, 4500 points or more
Based on the screen shots you are running on the demo license. If you go to System>Licensing>File Upload do you actually see the license files for the two PAKs that you registered? Just out of curiosity, did you activate the PAK online (www.cisco.com/go/license) and then upload the .lic file Cisco sent to you? Did you doublecheck the MAC address associated to the machine in the .lic file (it is a text file)?
The point is something is incorrect in your .lic file.
HTH.
Bill
osamaokok Tue, 05/04/2010 - 07:44
Hi Bill
Yes i activated the PAK and i got the license file on my email also double checked the MAC and it is the same i filled in cisco license pages.
William Bell Tue, 05/04/2010 - 08:00
OK.  The .lic file you got in your e-mail.  Did you upload that to your CUCM-BE server?  I believe that is what Hailey means by "installing" the license but maybe there is some magic I am not aware of here.
Did you go to the section on your CUCM-BE server where you can view the files that you uploaded to the server to activate the license?  Can you confirm that you have uploaded everything correctly?
If so, then the next step may be to restart the License Manager service.  If you didn't do this when you uploaded the .lic files to the server then this would be an issue.  Maybe even "the" issue.
Check:
1. File upload section to ensure you uploaded the correct license files
2. Restart the License Manager service
3. Let us know how it went
HTH.
Bill
David Hailey Tue, 05/04/2010 - 08:05
Yes, that's what I'm talking about. In the original post, you stated that you installed "CM7-PAK and UNITYCN7-BE-PAK". So, take a look at what Bill said and we'll go from there. I have CUCM-BE server in my lab if I need to hop on and see if anything is different than I remember it to be.
Hailey
osamaokok Tue, 05/04/2010 - 08:12
Yes i can view the .lic file here is shows smething like this:
INCREMENT SW_FEATURE cisco 7.0 permanent uncounted \
    VENDOR_STRING=1XXXXXXXXXXXXXXXXXXXXXXXX2.0 \
just as a sample where X is the MAC
when i tried to uploaded again is shows  file Error: [1023] A file with this name already exists in the license file  directory
I also Restarted the License Manager service but it is still shows demo license.
David Hailey Tue, 05/04/2010 - 07:24
All of the systems come with a Demo license that is installed by default. It appears you may only uploaded your new licenses to the system but not INSTALL them.
Hailey
Please rate helpful posts!
osamaokok Tue, 05/04/2010 - 07:46
Hi David
What you mean with only uploaded your new licenses to the system but not INSTALL them....?
cm6043 Tue, 11/09/2010 - 23:16
Hi  Osamaokok,
I have the same problem as you (showing demo licenses). Did you reslove the problem ? If so, can you let me know the method ?
Thanks a lot
Leung Che Man
