%QOS-4-FO_IN_USE: Releasing feature object with reference count [1]
May 4th, 2010
I would like to know if having this error message on a router (%QOS-4-FO_IN_USE: Releasing feature object with reference count [1]) could affect the QOS? ie : Excessive latency etc etc
According Cisco this is an internal software error. A QoS policy feature object has a stale reference. Is someone knows what does that mean? Or if there is any consequence on the QOS?
Thanks in advance for your help
Mel
